'99 Taurus Wagon 3.0 24v
I am replacing the power steering pump and decide that because I also have a small coolant leek it would be a good time to replace the water pump. I have removed the power steering pump, but the water pump has an interesting problem. It does not have enough room to come out of the engine compartment. All 4 nuts have been removed, but when I try to remove it it hits the wall before it clears the studs.:eek: I need another 1/4" or so. Short of pulling the engine, any suggestions on how to get the extra room? I have tried using a prybar to try and push the engine over but decided that it might not be a great idea.
I have tried un-screwing the studs, but the stud on the engine side is longer than the one that holds the water pump.
There are 2 or 3 separate posts in the topic finder on removing the water pump from a 24v engine. Did you even look there?
(PS - you have to go at it through the right front wheel well.)
I know on a gen 1 with a 3.8 you have to unbolt the front motor mount and raise the engine a bit to get the water pump out.
Thanks everyone. The correct answer in this case is remove the nut from the front right motor mount (very easy) and jack up the engine 1.5". I did research all the posts regarding water pumps and was not able to find a solution. Finally my son suggested lifting the engine. (Smart kid).
Thanks again.
Did you check in the topic finder @ top of this page for gen.3 tec water pump removal how-tos? No need to jack eng.
Have never had to jack a Tec to change a water pump, ever. The correct (easiest) way to do it is in the wikki (Topic Finder), through front right wheel well. Pulling a plastic fender liner is a whole lot easier and quicker than jacking the engine up, but kudos on doing it yourself, either way!
