Hello everybody!
There is a year 2002. Ford Taurus.
The problem is that it has no gears. When the car is started - and Gear lever shifted - nothing happens.
I changed transmission fluid, and filter - and as I noticed - there also is no pressure in tranny. Could it possibly be because I just removed oil pan, without draining it through the radiator?
second problem - wanted to check TRS, but I'm stuck on the part, where I have to remove it.
unscrewed 2 holding bolts on the sides, and one in the center - but seems it is still holding to the rod, which goes into tranny. Please don'' t say, that I will have to drain the tranny again, to release that rod from the bottom.
Any help and suggestions appreciated!!
Best regards!
Best regards!
