<div align='left'>
Hello, all. I sure am glad to find this place. I've been struggling since moving to north Texas
with my '94 Taurus Wagon GL (3.0 litre).
It runs great, despite some old car idiosyncracies...but whenever we have damp weather, the
doggone thing just won't start. It cranks and cranks and cranks...but I generally have to wait
for a warm, dry day before I can drive again.
I've replaced plugs, plug wires and ignition coil wire...and it started...reluctantly...and only
after a shot of starter fluid. After that, it ran fine. Then I tried again a half-hour later and
it cranked...and cranked....
Sigh.
Sure would appreciate suggestions.
Thanks.
I had the same problem. Went through the same fixes on a Windstar. Turned out the coil was getting damp inside on damp days. Replaced the coil and it was fixed.
QUOTE
Turned out the coil was getting damp inside on damp days.[/b]
The COIL is a sealed unit, I've never seen one get wet/damp internally. Did you mean the distributor cap??
Have you checked fuel pressure with a guage? It almost sounds like it might not be keeping "primed". If it's only on ultra humid days, it could be condensation inside the cap, being a 94. Do you still have that infernal black rubber cover on the distributor, take it off!!!!
Has the car been in high or even semi-high water?? If so I would start looking at electrical connections.
QUOTE (rudedog @ May 15 2009, 11:35 AM) index.php?act=findpost&pid=725350
. The COIL is a sealed unit, I've never seen one get wet/damp internally. Did you mean the distributor cap??[/b]
On the Windstar the coil had a hair line crack along one entire side along the bottom where the clear/white plastic was welded to the black plastic top.
His 94 doesnt have a coil pack, just an ignition coil for the distributor.
I'd check into doing a cap+rotor, and ignition coil. The fuel pump might be a suspect as well.
