Anyone have advice on finding the best wheels for a 2002 Ford Taurus? I'm trying to replace my stock ones without buying a new set of tires. I believe the size is 16x6/6.5.
my 2003 is 16s - and I would suggest going to the junk yard. my local yard charges $25.00 for rims. Typically there are 7 to 8 3rd Gens in this yard all the time. If you going custom TireRack has a calculator that is easy to use also. Good luck TireRack
It’s not just width and diameter. You will also need to take into account offset and center bore. I will try to find the calculator that I uploaded which will show tire and wheel sizes and it will show you how much farther in and out everything is and how much shorter or taller everything is.
I would check any of the popular for sale sites and apps. You might search for “5X108.“ That is the lug pattern. Some wheels, like for the Lincoln LS, have too much of an offset for our cars. Depending on the width, you might find tires wheels from Volvos, Ford Fusions, the Ford Focus, Jaguars, and a lot more.
I’m not sure if you were looking for a factory or aftermarket rims. Either way, if you want to change the width for a later tire size change this might help out.
Who's good with some numbers? I've got a spreadsheet that I was hoping people might look at to check my math. I want to add some larger wheels and tires. Of course, I know it's not that simple. Width, offset, clearance, tire circumference, and more all come into play. I found some websites that...
www.taurusclub.com
Related Threads
1.2M posts
85.9K members
Since 2003
