yesterday i was checking the a/c system as the compressor will not kick on. i jumped the low pressure switch and then the high pressure switch to see if i can get it to kick on. today i left for work and the heater doesnt work. only cold vent air comes out of the vents. i checked the fuses they all seemed ok, but i am going to check them again. any idea what may have happened? the radiator fluid is full the thermostat is opening correctly and the car run normal temps. car is a 1996 ford Taurus. 3.0
Sounds like the blend door quit working. Do you have EATC? If so run the diagnostic test.
it was a blown fuse i overlooked. the blend door was not actuating. so i checked the schematic and found a fuse i missed and that was it.
