Great site you guys and gals have here. I do need help!! I have a '93 taurus 3.8l with 200k on it with the motor recently rebuilt. The problems are:
#1 The engine seems to be spitting at idle and misses upon accelleration. Codes read- 136, and 172 (both sides running lean). I ran around the engine with propane and I didn't seem to find any vacum leaks. I also sprayed electric contact cleaner on the MAF sensor elements ,cleaned the air bypass valve, cleaned the throttle body, replaced the temp sensor, etc... I think I'm in need of new ego sensors but......I'm getting different answers as to the sensor part numbers... whether the two sensors are the same or if they have different part numbers???? What to do ????
#2 I had the tranny housing replaced by the dealer b/c it had a crack in it, thus destroying the starter and flywheel. Since then I had two flywheels replaced ( at $400.00 per job) and I just replaced the fifth starter drive. Everyone is stumped as to why!! When they rebuilt the engine they said that a new crank bearing was installed (oversized I think). WhenI start it on occasion it seems like the engine is "back starting".....does that make sense?? It seems to be reaking havick on the starting system.
The car itself is in exceptional shape, wine in color recently painted, and solid. But if I can't resolve these probs. it might have been all for nothing, then I'm just stuck in debt with nothing to drive the wife and kids around in. Please lend your wisdom and experience and get me back in shape... Thank's a lot!!
