Originally posted by hoss@Jan 13 2004, 03:21 PM
there are three big wires under the hood that you will STRONGLY benefit from changing. ill drag up which three they are later, but if you change the stock wire from these three with bigger gauge wire, this will help out your charging syste. the same goes for the power wire leading to the amplifier. the bigger the wire, the less internal resistance, the less current draw.
also a better battery will help alot. you dont have to go optima or any of the expensive audio concentrated brands. i noticed a huge difference just using a batt from wal-mart, just lok for the most cold cranking amps. an audio specified battery will be better, but the cheaper alternative may work as well.
dont get a cap, they are useless, i can explain if i have to, but its lengthy.
P.S.--where can i get the 220 amp SHO alt?? and how much?
