My 1990 Taurus has (3.0L) has been giving me commuter nightmares this past week. It is an intermittent problem that has cropped up occasionally since I bought the car in late 2000 - this week is the 3rd consistent occurrence of the glitch.
Here's the problem.. while driving, the fuel pump (sender) will quit working, causing the engine to stall. Sometimes, the sender cuts out only for a split second, and the momentum of the car restarts the engine, resulting in only a momentary hiccup. Other times, I get a complete loss of power and have to drift onto the shoulder. It might take 10 seconds to 10 minutes before the sender starts working again and I can restart the engine. There seems to be no correlation to speed, engine RPMs or the amount of fuel in the tank.
After the first occurrence of this glitch, I took the car to a mechanic, who ran tests on the sender, electrical connections and the fuel system, and was unable to find anything amiss. I have had dozens of theories on the cause of this problem, including:
* A faulty ignition module that could be preventing electrical current from reaching the sender.
* I have heard rumours that the sender in this vintage of Taurus had a known fault, which would cause this sort of episode and can only be fixed by installing a new sender
* Weather conditions? I've suspected that excessive dampness or condensation could cause the sender to short or otherwise malfunction.
I would appreciate hearing from anyone who has had similar experiences or might know what I can do to correct this problem. Having to drift dead stick across 4 lanes of rush-hour traffic to the shoulder is starting to get on my nerves!!!
Many thanks,
Stephen Parkin
Many thanks,
Stephen Parkin
