sure you can. but i would check the engine codes on both to make sure they are compatible. if not then you will be doing alot of wiring and have a big head ache with parts
I Have A 1997 3.0l Taurus I wanta Know If I Can Put That Motor Into A 2000 Taurus?
If its a Vulcan, you will need to swap the split plane intake onto the donor motor. And ALL of the old motors wire harness onto the donor motor.
