I have a 92 GL Wagon. Last night I blew a fuse on my hazard/turn signals. I replaced the fuse and the hazards work fine, but the turn signals will not work. I replaced the flasher. Still have the hazards but no turn signal. Then I changed out the multifunction switch. No change still. Anyone have any ideas?
Yeah you can use hand signals.......
Or it could be your turn signal switch steering column.
the flasher runs both the flashers and turn signals, so thats not your issue.
Most likley its not your turn signal swich. Id say theres another blown fuse.... Check under the hood and dash.
Brad
UPDATE....Studied the schematics for the car and came up with the answer. Power comes into the multifuction switch through the flasher first. And power comes into the flasher from TWO fuses. One is for the hazards and turn signals and the other is for the instrument cluster. The fuse for the instrument cluster was blown. Replaced the fuse and now everything works again!!!
Maybe this is a common problem? Ask one of the mods, cause they have a new forum about common problems.
Seems unusual that there would be two fuses, but if that fixed it, great :D
