1 - 2 of 2 Posts
My car is in the driveway, the bumper removed and all. I am trying to install secondary transmission cooler, however, I am stuck at disconnecting the tranny fluid line from the radiator. There is just not enough room to access it unles I remove the entire radiator and everything else.
The car '99 Taurus with AX4S transmission.
Any tips would be appreciated!
Follow the lines to the drivers side. It should be a metal pipe that runs under the radiator then connects to rubber hose. Connect the cooler there on the drivers side of the radiator.
1 - 2 of 2 Posts
