· Registered
my friend who had a taurus car suddenly started smoking out the exhaust thick white smoke , could this be the head gaskets or the heads cracked?
exhaust smells like antifreeze, thinkin about trying some bars leak in the cooling system to see if that helps,
any help would be great asap
thank you
· Registered
wouldnt use that stuff. but its up too you
· Registered
Be aware too that the radiator will likely leak too. This happened to me with my 95 Taurus - the dealer said that the end caps on the radiator are plastic & will crack when you start pumping all that pressure that normally remains in the cylinder into the cooling system.
