about 8 months ago I had the A/C serviced and pressure tested. at that time, i was told that the A/C was in good working condition. the other day my wife was driving the taurus and the A/C just stopped working. Upon further investigation, I found that the compressor was not spinning. I spun the compressor slightly by hand and it doesn't seem to be binding or anything. as far as I can tell I think the clutch is in good shape. Personally, I think the compressor isn't getting power and it is a relay or fuse--at least that is where I'd like to start. The Chilton I have seems rather useless on telling me what fuse to check or where the applicable relays are located that send power to the A/C clutch coil.
Can anybody point me in the right direction of where the fuses/relays are located? Car is a 1994 Taurus with the 3.0 Vulcan engine. --any help is greatly appreciated. --Thanks
Discussion Starter · #2 ·
unfortunately I do not have an owners manual with the car. i did search the topic finder but did not find the location of the fuses and relay
With ac set to on, unplug and jumper cycle switch plug (wire side) atop the accumulator on pass. firewall with paperclip bent u-shaped and see if compressor engages. If compressor starts, replace cycle switch.
Unless, there is not enough refrigerant(pressure) in the system to make the contacts in the switch.
I would second switch jump. Also, have someone check it for refrigerant either way. The do-it-yourself cans aren't foolproof and are no substitute for a real set of gauges and someone who feels confident with refrigeration systems.
^ Yes, if system is empty, it needs to be checked for leaks, repaired, possibly flushed, pumped down and recharged.
If you check hard enough I'm sure you can find a owners manual of your cars year. This will show you the fuse and relay location .;)
