· Registered
I recenlty tried to start my car (1998 Ford Taurus - Automatic) and nothing happend. It was like there was no battery at all in the car. Once jumping the car, it started immediately. I checked the battery using a volt meter and it read 12.95volts which should have been strong enough to start the car. Correct? Well after that I disconnect the wires to the battery and clean the posts and the terminal connects (and ground too). Still nothing. Then I checked fuse and everyhting seemed ok. NExt I noticed that the Mega Fuse block under the hood had some corrosion, so I disconnected the wires and the fuses and cleaned up the connection here. I'm not sure if I put everyhting back together in the correct order. There are three wires and one fuse. Does it matter what order they go back on in??? Next I disconnected the "starter & selanoid" and took them to the parts store to have them checked out. They both seems to work just fine. Next I switched out the battery with a battery from another car (kinda old but still ok) Now the car kinda starts....The starter sounds like it's just spinning. Do I need a stronger battery or did I just miss something when I put the wires back on the mega fuse or the starter/selanoid???
Please any help would be appreciated.....I cannot take being locked in the house another day without my vehicle.
thanks in advance !!!
· Premium Member
Put the Volt meter on the battery and have someone turn it over.
What does the voltage drop down to?
Mike
· Premium Member
12.95 V when the car is not running is too high. The battery is toast.
On the mega fuse, the main cable coming from the alternator should be on the post towards the radiator. All other wires should be on the engine side of the fuse.
· Registered
Purchased new battery....cleaned all the terminals and I think I have them back in the right order and in the correct place. Cars will now START but I'm seeing an idoit light on my dashboard of the battery. Do I need to reset my onboard computer or what? I ave the one cable from the battery going to the mage fuse terminal closest to the motor and the other two are on the radiation side with the fuse sandwiched in between the two on the radiator side. Is this correct? Car starts....windows work ....lights....but I'm still getting a Battery light on my dash.
confused ...Please help again.
· Premium Member
The large alternator wire goes on the radiator side of the mega fuse. There is also an orange wire that goes on that side. All other wires go on the engine side of the mega fuse. Your mega fuse is good yes?
If the battery light is on the alternator is not charging. Your new battery will soon be dead. There is also a 30 amp fuse in the engine compartment fuse box that goes to the alternator. Be sure this is good.
