I am trying to finish up a labeled diagram of a Gen-4 Vulcan engine and have identified about 30 parts that I would like to label. I have figured out what the 14 of the 30 are, but would need your help in identifying the remaining parts (numbered 1 through 18 in the picture). Any help is greatly appreciated. Thanks.
1 = ?
2 = looks like main vacuum supply to brake booster
3 = throttle cam assy. snow shield
4 = coolant temp. sensor
5 = fuel rail pressure sensor
6 = either a/c or pwr steering muffler
7 = cant find it
8 = alternator
9 = pcv vent hose
10 = vacuum supply
11 = coolant pipe
12 = transmission
13 = upper radiator hose
14 = same as #6
15 = cant really tell, but the pcv elbow is right there
16 = again cant really tell, a/c pressure switch connector?
1 -- tube from PCV valve
17 (if the can-like thing at the back of intake manifold) is the manifold runner control
18? (can't really tell the number -- it's between 2 and 11) throttle position sensor
9 is a simple valve cover vent (the PCV valve is on the other bank)
I know this post is three years old so its a long shot but if you can post the finished product for this map, I'd really appreciate it. I had a lot of questions answered from this post already but I feel like it may answer a few more if you still have this finished product available.
Thanks!
