I've been trying to find the right part numbers on the forum and the web, but I keep getting different brands and part numbers.
2000 Sable Duratec DOHC, and I believe the transmission is AX4N
I can't remember the codes, the mechanic said misfire in two cylinders, and some strange ticking/rattling like noise in the back of the engine when accelerating. Will need to inspect the manifold and plenum I believe. It has 172k miles, and I want to repair/maintain it to last for a while without any problems.
I have to have the parts ready before we start working on the car to avoid going to the expensive dealer/shops.
Here is what I found that will most likely should be replaced so far
Fuel filter: Motorraft FG1060 Filter
Serpentine belt: Gates K060755 Multi V-Groove Belt
Transmission pan gasket: Fel-Pro TOS18709
Transmission filter: Motorcraft FT130
Spark plugs: Bosch Platinum +4 Spark Plug 4458
Coil: DG500
Correct me if I am wrong, but should those spark plugs wires on the 2000 Duratec be replaced normally?
Appreciate it.
Coil: DG500
Appreciate it.
