Hi everybody,
97' 3.0 Vulcan with 186k miles, rebuilt engine at 168k miles.
Back in June of this year the cam position sensor failed on me causing the oil pump shaft to jam and chip one of the teeth on the camshaft. At that time I decided to park it and tear down just far enough to get a bore scope in to confirm the damage - 1 single chipped tooth on the camshaft gears. Thankfully no indication of any serious damage due to low lubrication even though the oil light did flicker for a few seconds before I could stop the engine. All cylinders pass leak down and compression test.
At this point I'm inclined to replace everything from the oil pump, shaft, synchronizer, position sensor and the camshaft itself.
So first question, and believe me this goes against my gut instinct, is that one missing tooth on the camshaft a show stopper or should I go straight for the replacement?
Second question, in the course of replacing the camshaft has anyone had any luck just loosening the carriage from one end, unbolting it from another and just tilting the entire assembly down toward the right side of the engine until there is clearance to slide the camshaft straight out ? I know this sounds a little bit outside the box but I'm trying to avoid having to yank the whole engine out of the car believing this might be faster if it actually works.
Thanks in advance,
- Troy
Thanks in advance,
- Troy
