1 - 9 of 9 Posts
So... I screwed up my wiring harness. I took the wires out of the plastic connector and can't figure out what spots the wires go in.
Can anyone post a picture or an explanation? I mean the wires that go from the connector to the bulbs.
be more specific... what connector? what part of the harness? there are hundreds of connectors and about 65lbs worth of wiring
the first connector once the wires go in the trunk for the passenger side brake light.
I need to know what slots the wires go in on the part that goes towards the brake light, not the side that goes into the car.
Can you look at the one on the driver's side to figure it out?
Tried that but I think it is mirrored. I tried to figure it out and couldn't. I also tried matching the colors of the wires to the wires on the other side of the connector and that didn't work either.
The connectors are the same. Get an ohm meter and trace down the contacts in the socket with the wires.
I have the short harness' for both sides (from the trunk out to the rear brake lights) laying out. I just replaced a harness, so if you want, I will take pics and post them tonight when I get home.
<div class='quotemain'>
Yeah, that's what I need. Thanks :)
All my tries were WAYYYYYYYYYYYY off. It's fixed though :)
Thank you :D
1 - 9 of 9 Posts
