1) How much is it at an auto parts store?
2) What parts are highly recommended to be sprayed with that ****?
1) How much is it at an auto parts store?This **** is your friend.
[attachmentid=22110]
Not too bad. Seems solid enough for now. Any Idea how think the pipe is?
I think I will just soak it in wd40 before I put it on and do so every so often. The rust converter stuff is only good up to 200°F. If the black paint is bubbled up like mine, jsut putting wd over that will probably not help as the moisture is trapped underneath that. My theory was to open it up and let it breath. The heat from the coolant should keep it dry for the most part. Just have to worry about the salt.
A quick pull of the wheel well splash guard and a nice lather of wd should do fine. If I need to replace it in the future, I know how and shouldn't take too long.
I just want to get my car running again. :rant2:
1) How much is it at an auto parts store?<div class='quotemain'>
This hose just went on my 1998 Taurus DOHC. I got the old hose off but cannot manuever the new hose to get it in the correct position.yea this is part that I have trying to find also.Dealer told me the part is being discontinued, so soon even the dealer will not be able to get these. I ended up coating the pipe in high temp epoxy resin and then painting it with chassis black. At this point in time I hope it holds.[/b]
QUOTE (lgranch @ Aug 23 2007, 10:22 AM) index.php?act=findpost&pid=525834
I pried the pins out very carefully and they look like I will be able to use them again.Jkenny, I ressurected this old thread to try and help us both. In order to remove the fender liner, did you cut the push pins or did you just yank on them to remove the liner? Will they be re-usable or should I buy new push fasteners? Thanks and from what I have read, it may just take you a while to position the pipe.[/b]
QUOTE (jkenny7512 @ Mar 20 2009, 09:32 AM) index.php?act=findpost&pid=710637
QUOTE (clydesdale @ Mar 20 2009, 10:02 AM) index.php?act=findpost&pid=710652
That would have been 10 times easier than installing that ridiculous pipe. Wish you had posted the suggestion and pictures sooner.Some notes:
1. Use hacksaw to cut old one in half for easier removal.
2. Replace with flex hose from AAP.
3. Bangerang.
[attachment=28946SC01407.JPG]
[attachment=28947SC01408.JPG]
[attachment=28948SC01411.JPG][/b]
QUOTE (WagonFreak @ Mar 22 2009, 11:24 PM) index.php?act=findpost&pid=711342
3. Bangerang.
Some notes:
3. Bangerang.
So when you say Cut the old one in half... are you talking about the clamps or the pipe itself. I can't access the clamp towards the front of the car... God blessed me with big hands.Anyway... someon suggest cutting the clamps with a hacksaw in the Ford Forum... is this what you mean?
I'm having a lot of problems removing the clip off the pipe attached to the front end of the car. The pinchers were facing up and were unreachable from the bottom. Being the genius I am, I took a dremmel and cut part of the clip... and half of the pincher came off... but the clip itself is now shaped like a C and still clamped pretty tightly. Any suggestions on removing this thing. I'll post pics... my car has been down for nearly a month now.I only cut the pipe.[/b]
Well... using a Dremmel and some long flat head screwdrivers I was able to cut the clip and then pry it off. After I got it off I had the new hose on in about 20 minutes (Using Wagon Freaks Technique). And everything was all good... but appearantly I now have another leak somewhere. I'll have to get it figured out this weekend.Can you get a choker (slip knot) of braided wire around the remaining pinch tab of the clamp so that you can pull it in the opposite direction of the way the clamp is wrapped around the hose. If you can do that, you can make a handle on the other end for leverage. Wear gloves in case the tool slips.
Good luck, Popeye[/b]
