Need 2014 ford taurus radio wiring diagram without sony
419 Views 5 Replies 3 Participants Last post by  AdrianD310
see pdf attached. It is the pin info for the pigtail you have pictured.
  • Like
Reactions: 2
Font Material property Parallel Paper Handwriting
ty that was that right one would you be able to tell me which pins I would need to wire this line out converter in? And which pin to wire a Remote on switch to the amp?
See less See more
There are wire harness adapters that plug into the car's wire harness (connector) and you would then connect each wire to the new radio's wire harness. These maybe easier and is what I used for my 2007 Mustang.
  • Like
Reactions: 1
Font Rectangle Screenshot Parallel Technology
Font Rectangle Screenshot Parallel Electric blue
Be careful modifying your wiring harnesses. It’s not hard to do, but finding this info wasn’t either so please, do not under any circumstance attempt to do this work unless you are 100% sure you can.
See less See more
2
  • Like
Reactions: 2
Circuit component Font Automotive lighting Cable Electronic component
would something like this work I've looked everywhere but this is the closest one I could find?
See less See more
