Originally posted by somedude@Oct 19 2004, 04:56 PM
beofre you go all out and spend the big bucks on a brake flush (about $3.95) check the fluid condition if it is black or dark in color or the peddle is "soft" then flush it other wise it is not a necesity.
have you ever done front brakes of a taurus? there are 2 bolts 10mm or 12mm (theyre not real big) I think that hold the calaper on to the calaper bracket remove them and remove the calaper.
if you are doing rotors you need to remove the calaper brackets remove the 2 larger bolts 15mm (pretty sure on the size) and the bracket will come off, and the rotor will slide off after the bracket is removed, if it is rusted up smack the hub on the rotor a few times to break it free.
resurfacing rotors is a normal practice
Imagine that this is the rotor surface
and the old pad is worn to match the rotor so there is 100% contact
the new pad is like this
and if the rotor is not resurfaced you have to wait for the pad to wear to the rotor's imperfections before 100% contact is achieved, 100-200 miles should be enough, your brakes just won't bee at their best, why are you going through rotors so fast?
if she is dragging the brakes (even slightly) it can cut your brake life by 65% easly and cause warping of rotors. when you releas the brakes it allows the rotors to cool and when they are not being fully released they can overheat very quickly and at extreme temps pads wear very quickly.
ever see someone drive 100 miles with their E-brake on even if its just a little bit the rotors can begin to glow or smoke heavly.
I drive my car VERY hard and my front brakes have 50% with 12,000 miles on them
where abouts in NY do you live? I live in cheektowaga, or buffalo
the rear brakes are a bit more involved because the calaper has to be screwed in unlike the fronts that you can use a C-clamp to compress. most parts stores have the tool you need to fdo this, it is a cube and firs into slots in the piston and you use a ratchet to turn the piston in.
