· Registered
While replacing my starter I noticed antifreeze on the back end of it. (where the wires connect) Also the oil pan was leaking.
Got a oil pan gasket set, removed the new starter, removed the y-pipe, dropped the pan and replaced the gasket, no more oil leak
My problem is I can not tell were the antifreeze is leaking from. It started last month and I am losing alot of antifreeze. (about a bottle of 50/50 pre-mix every month) My question is what is around or above the starter that could be leaking? I would prefer not to take it to a shop until I have tried all I can so if you guys and gals can give me any suggestions I would appreciate it.
