My sister has a 90 taurus 3.0. Heres a little history...she got it from an auction 3 years ago, 450 bucks, 130k miles. OK, when she first got it...i noticed when it would idle it would vary in rpm a little and in rythem. like vroom, vroom, vroom, about with my pulse of my heart at rest. maybe 300 rpm surges...anyways, it ran perfect while u drove it though, this was only at idle... driving along at constant speed, it would not surge at all. well, she said about 2 weeks ago that it wasnt running right, so i went to drive it and just to keep it running you would have to hold the pedal floored and it would major surge, like from almost die (350 rpms) to like 4000 and back, not like rev limiter or something it would rev up then just die... now it wont even really run...u hit the key and it sputters and dies...even if you pump and hold the gas it dies imediately after starting. I pulled the codes off the computer and they said 21, 22, 24, 41. 21 is Engine Coolant Temperature (ECT) sensor out of range - ECT. I dont think that would cause it not to run at all though. 22 MAP (vacuum) or BARO signal out of range - MAP. Now...my dad is a Heavy Machinery mechanic on like bulldozers and crap and he thinks that the MAP woudld cause it not to run. is this true?? 41 ® System lean - Fuel control (M) System was lean for 15 seconds or more (no HO2S switching) - Fuel control. thats the other code. not real sure how to fix that...24 Intake Air Temperature (IAT) or Vane Air Temperature (VAT) sensor out of range - IAT VAT. not sure what that is...I traced all the vacuum lines and the rubber hose that comes right out of the PVC valve had a huge hole in it...so i got a new PVC and cut the bad spot off the hose (the hole was right by the pvc and the hole was short enough i could cut it and it still reached the pvc easy...) The rest are ok. now... i posted all this on the taurus car club and one guy responded by saying that it was that idle air control thing on top the motor... now...i dont agree because it surged so bad even at high rpm...i thought when those go bad that the idle would just be stuck really high or inbetween not varying with the throttle. nobody else responded. the car has 160k miles on it now. my thoughts were maybe the fuel pump, like it has enough to start it, but not enough to keep it running, and maybe that weird idle for the last 3 years was the hole in the vacuum line by the pvc. my dad thinks its the MAP, but woudld that cause the car to not run at all like this? I dont think that oxygen sensor error would be enough to not even allow the car to run...?? I drove my supercoupe to the exhaust shop with them laying on my workbench and it drove fine...Anyways, What do u guys think?? MAP? Idle air control? fuel pump?? anything else? my sister pays for her own college and really doesnt have the money to pay 40 towing and who knows how much to get it fixed...keep in mind its a 450 dollar car 3 years ago...Thanks
