Okay here is the problem.....my heat blows a little but it stops when the coolant gets low....it leaks when the heater is on but doesnt leak when the heat is off...the heater inlet hose is blistering hot but the outlet hose is cold....figured id get so gasket seealant but i think its only leaking because of pressure from it being backed up somewhere...any body?
sounds like your heater core is plugged up....how does your coolant look?? how often has it been changed or has it ever?
