1 - 20 of 32 Posts
Sweet, get a video up :)
I want my exhaust to look like that on my Taurus. Is that only mufflers or what? And where did you get it at and for how much?
QUOTE (Eric1987 @ May 23 2010, 03:56 AM) index.php?act=findpost&pid=806237
I want my exhaust to look like that on my Taurus. Is that only mufflers or what? And where did you get it at and for how much?[/b]
i had the 3rd cat and resonator removed. its true duals with two flowmaster 40 series mufflers. i got it at a place called arrow truck and muffler in hertford nc. the guy has a bunch of sho's so he was perfect for the job it took 2 days for him to do it and it ran 500 bucks
What size piping did you get? And you have an X pipe on there now? Was there an O2 sensor in that cat you removed? And get a sound clip on here!
QUOTE (Eric1987 @ May 23 2010, 11:10 AM) index.php?act=findpost&pid=806267
What size piping did you get? And you have an X pipe on there now? Was there an O2 sensor in that cat you removed? And get a sound clip on here![/b]
O2 sensors are not on the third cat.
Also... True dual??? Post some pics bud!
Are you located out near the OBX?
Discussion Starter · #15 ·
i can tell a little difference in the power. i love the sound of just cruising threw town it sounds very deep while cruising
That sounds AWESOME!
Can we can a pic of the pipes coming off the cats? I'm still a bit skeptical on the "TRUE DUAL" aspect. btw, your check engine light is on.... might that have something to do with the exhaust? Without a proper tune, you may actually be losing power due to a lack of scavenging. It does sound good though.
As far as that wire goes, there is a grommet on the side wall btween the ebrake pedal and the sjb I used for the hood pin switch on my starter.
Looks like you did away with the stock y-pipe, as well as the 3rd cat. Here's where you might be a little upset. Ford put the cat for the rear cylinders on the rear exhaust manifold, and not the y-pipe, so you still have 1 cat on the car. Probably not all that balanced at the moment. :noes:
1 - 20 of 32 Posts
