1 - 16 of 16 Posts
Argh plastic endlinks?!!!!! NOOOooooo...
. Hmm, now that the entire front clip is out of the car, now's a good time to upgrade those springs and struts
Not to mention dress that bad boy up.
Discussion Starter · #10 ·
ive decided to use quick connects and finder screws on everything so i can just say "I feel like changine my rear exhaust manifold today...ill just drop the subframe!"
lol
Brad
Hey brad, can i do the mods you done on your duratec.. on my03 duratec???
Discussion Starter · #13 ·
yes...but you need to spend alot more than i did....you will need an IMRC box, 96-99 pcm, 96-99 UIM/LIM and adapt all the hoses that changed....
you could do it with your stock stuff....but youd have the split port heads with oval port UIM and LIM
also, im not too technical about this, but the cams really are a bigger benifit when you have secondaries...
Brad
hey are you or bob gonna be doing a write up on how to the contour svt change for the modifications section?
Discussion Starter · #15 ·
lol.....NO!
way to much to write up...just follow the ford manual...it has pictures.
Install is reverse of removal...this is a key point
Brad
what is a approx. estimate for the costs of this w/out labor??? and what would labor cost??
Jesse
p.s. would it be cheaper to just like umm get a turbo or super charger? LOL
1 - 16 of 16 Posts
