· Registered
My door ajar is stuck on. I was searching for a fix in the old post database. I still have a few questions.
WD40 or electronics part cleaner? Which works best?
Where do you spray it? Do you stick the hose anywhere in there?
Most importantly, is there a fuse I can pull till this sensor gets fixed?
· Registered
I solved my Door A-Jar problem by opening all 4 doors and really spraying the latches down with Electical Contact Cleaner, until it drips out the bottom, after this dries repeat it with the WD40 and that should solve your problem
