I hit a deer and had to replace the header panel. The headlights, sidemarkers, and parking lights work, but not the other stuff. I've changed bulbs and the fuses look ok. Is there a way to pinpoint this or am I going to end up taking it in?
make sure you check all under-the-hood fuses. a lot of people miss this, I was one of them. If all your fuses are deffinatly good the there's a high chance it's your multifunction switch( the lil handle with the turn signals, and washer blade controls. Those have been known to go out. another thing is in the wreck you moght have cut some wires. The main power wires for the HL and signals run under the driver fender and comes out by the batterey. If you pull the driver side inner fender you can get a good look at it. Also after they enter the engine compartment they run under the header panel. Just a few things to look at.
Wes
