I own a 2002 Ford Taurus.
On my way to work today I turned on my right turn signal to take an exit. There was a buzzing noise and then my turn signals and the radio no longer worked. On further inspection, I've noticed that the power locks, windshield wipers, interior lights, and rear defroster no longer work.
Does anyone have a lead as to what the cause might be?
I am not sure but start with fuses. Check for good ground, several under the hood. How is your battery, these cars sometimes behave weirdly if battery is getting weak. Also search or take a look at multi function switch which is in the steering column. Just some thoughts, good luck.
Scott
I agree with Scott, i have a 2003 SE that acted weird due to corroded battery terminals.
Just wondering if you have made any progress with your problem? If you can post with further information I am confident someone on this forum can help you.
Scott
