Purchased a full set of Monroe Quickstruts and going to install them and it became quickly apparent that the strut mounts were not oriented right (Not lining up with the holes). So had to disassembled and reassemble them properly.
Anyone else run into this problem before?
Not lined up how? Anytime I've installed Monroe or KYB's, all I've had to do to line things up was grasp the strut body on the lower end and give it a twist one way or the other.
AND the Solution is that the Bearing Plate and Mount on top of the "QuickStrut" (That the Studs are Affixed to)are "Rotatable".
...and that's because the whole shooting match rotates when the car is steered......
