2003 Sable DOHC 112K. Florida car.
I've been using conventional oil, and changed every 5k miles (changed to 10w-30 because of small leaks on the exhaust and that stopped it).
I've been trying to find more info on extended oil and filters, and decided to go with Mobil1 Extended performance full synthetic (NOT high mileage), and Fram XG2, which are both rated for 20k miles. Of course I won't fall for the marketing part of 20k, but is it safe to go 8000 miles between oil changes, instead of 5000 with the conventional? I simply want to have more time between oil changes, and also use a higher quality oil.
I looked for info in the forums, but I only found scattered mentions of this oil and higher end filters.
Thanks for the input
