Tonight when i was out taking a picture of my headlights I decided I would take a couple of pictures of the speakers i custom mounted in my doors.
This is the driver side,
This was quite difficult to mount since I had to cut away sheet metal in behind the door panel. It ended up being a gamble because I wasn't sure if it was goign to clear the window mechanism. It did.
After learning on the drivers door, the passenger side went way better, and smoother, the lock on this door even works still.
I mounted my old Kicker 3 1/2" speakers in the bottom of the doors just to the rear of the window lever. Originally these were supposed to be flush mounted. I had cut only the plastic away, so there would only had been carpet in front of them, they would have been hidden. However when I was trying to install the door panel, I couldn't get it to fit properly, I kept cuttin away sheet metal, finally I took the speaker out, cuz the fabric, and reinstalled the door panel. It still would not fit. Turns out the rod for the door lock was out of place!
So I made it ugly for no reason and now i have to try and find a lil grill to make 'em look decent.
