I'm hoping someone can provide some light on my recent brake experience
Last spring 2010 I took my 03 sel wagon (70k mi) in to the mechanic because I thought I had a dragging parking brake (which I use daily).
I could hear a grinding noise when backing out of the driveway but didn't notice it during regular driving and didn't notice a lack of braking performance. (Roters/Pads were new in Spring 08, Hawk HPS pads and mid grade slotted roters).
Diagnosis was a failed Master Cylinder and 2 seized calipers on the rear discs. Front calipers/roters/pads were OK but rear roters/pads would also need to be replaced.
I thought the MC had 2 "circuits" for controlling the braking, 1 path controlled the front passenger and rear driver brakes, second path controlled front drivers and rear passenger brakes.
I'm having trouble understanding how I could lose the 2 rear calipers and not have similar damage on the front end.
Thoughts and TIA?
I wonder if just the caliper slide pins were seized keeping the brakes applied on affected wheel(s) (rears are notorious for this), although ive changed out a couple of hanging calipers. I think the brakes (mc) are split diagonally so if you lose half, such as broken line and loss of fluid, you still have partial braking front and rear.
The brake system IS diagonally split (left front/right rear \ right front/left rear). I believe I read somewhere that it's a federally mandated safety feature since the early 70's (don't quote me).
As for the grinding - are you sure it wasn't just the morning surface rust? Aside from that, rear calipers are generally a pita with the slides corroding and pistons seizing. I had problems with rear calipers when I had a car with them, and now my brother has a car with rear calipers and, while not as bad (yet), he's having some of the same problems.
When I was dealing with it, I spoke with many parts guy who said the same thing.. one with a stories of late 90's GM's dropping the rear calipers on the road...
