Hey guys, the bearing on my 92 SHO AC compressor seized. So my sister was really nice and let me borrow her extra car, which is a 93 GL with about 170k on it. IT doesn't run good at all. The idle is super erratic, but once you start going it seems ok. The CE light came on, on my way home from work. Pulled the codes, and now I need some help deciphering them. Here is the list of codes I got.
136 - Oxygen sensor not switching/system lean Left or Front HO2S
167 - 167 No Throttle Position sensor change in "goose" test (must get at least 25% rotation)
172 - Oxygen sensor not switching - system is or was lean - Single Right or Rear HO2S
176 - Oxygen sensor not switching - system is or was lean Left or Front HO2S
211 - Ignition PIP signal was erratic or missing
326 - Pressure Feedback EGR shows low pressure EGR not seating or not seating intermittantly
411 - Idle speed system not controlling idle properly (generally idle too high)
412 - Idle speed system not controlling idle properly (generally idle too low)
536 - Brake On Off open or shorted to ground
Now the 167 and the 536 are because I didn't do the goose test right. Oh and the KOEO codes were 172, 176, 211, 326. KOER were 412, 172, 136, 411, 167, 536. To me, it seems like theres a problem with the EGR not working right, and probably some vacuum leaks maybe that is causing the lean condition. I could be wrong though. Let me know what you guys think. TIA!!
