Originally posted by JasonBVHS@Jan 27 2004, 04:43 PM
WILL a duratec or sho MAF, directly pulgin to the vulcans maf ports?
IIRC, all Ford MAF's have the same ports, so they should all interchange. Keyword being should.
Originally posted by 97GreenStreak3.0+Jan 27 2004, 06:50 PM-->QUOTE (97GreenStreak3.0 @ Jan 27 2004, 06:50 PM)
<!--QuoteBegin-JasonBVHS
IIRC, all Ford MAF's have the same ports, so they should all interchange. Keyword being should.[/b]
I dont think it would work. I attached a file, see the explenation. It appears it is caliblrated for the specific engine. Might physically fit though.
Yes, the sensor is calibrated to go with a specific engine, which is why you need a chip if you are going to upgrade to a different MAF.
However, Jason asked if SHO/Duratec MAF's will plug into a Vulcan port, and the answer to that question is yes. You're just going to need a chip to get it to work correctly. Does that make sense?
