1 - 2 of 2 Posts
Hi,
I changed the thermostat on the car. Seems some times it is warmer inside the car than other times but lately it has just been blowing luke warm air. I pulled out the radio to see if the blend door actuator is working and the arm moves up and down. When you turn the knob to cold it will blow cold and when you turn it to hot it will blow luke warm, not a major difference. If the blend door was stuck or broken it would not do this change correct?? I don’t understand the blend door and where it is or what it exactly does? The only thing I have not done yet is flush out the heater core. Any suggestions would be appreciated.
Thank you,
Keith
Try reverse-flushing your heater core.
Still no heat? Reverse-flush again. Or check your water pump.
1 - 2 of 2 Posts
