1 - 20 of 35 Posts
:D need help with deciding how much to lower my car i was thinking lowering it by 1.4'' but was wondering if that would be enough or if it will be to much can i see some pics of cars that have been lower by the amount im thinkin or been lower more :unsure:
my gen 4 sable with eibachs and kybs it sits pretty nice now could be a little lower in the front but i didnt do a full strut tab mod
These pictures make me excited to get my eibachs and order my koni's!:D
You don't have much in the way of options for springs, your only lowering option is Eibachs: SHO Source
Or as my grandpa who used to own my Sable said, "Use sandbags." :rofl2:
Paul do you have a splitter on the side there?
Konis use the stock G3 strut housing so realistically there should be no change in height from stock struts with lowering springs. They offer no up or down adjustment, just stiffness. Mine is done with stock mounting points. I don't know if Paul ever put Konis on the back or not, but he did have the SARCs with the tab mod in the back last I heard.
Konis only in the front. The back is stock height IIRC but I have the Eibachs back there.
Yes I have side air deflectors.
Notice any difference with the deflectors?
Any reason as to why you don't have the Konis on the back too?
I'm cheap. The rear SARC struts were fairly new and I don't have any complaints how the rear sits or handles.
Ha. Good enough reason for me. My rears were shot thus the reasoning for the new equipment. The rear plants now though. It's rediculous how much of a difference it is. Used to slide around a good bit now even with skinnier tires its more planted.
Did it help with lift in the rear when you get on the brakes hard?
It helps with weight transfer in every way. It may just have been the worn out stuff but the car bites harder under accel and decel. I felt like I was dragging the nose when I braked, but now it feels flat.
An easy route is to get lower profile tires. I went from a 205/65R15 to a 225/50R15 and it's low enough that when a shop drives it up onto thier lift it scraps the ground. It's quite noticably lower, about an inch. You also get a little more acceleration with the small diameter tire.
I'll be going back to the original size for my next tire selection.
My 97 SHO with Eibachs:
What a HEAP
Mike
:rolleyes:
<div class='quotemain'>
What about the horrendous wheel gap
Mike
:dunno:
1 - 20 of 35 Posts
