i am trying to replace my rear springs on my Gen 3 wagon and was attempting to drop the rear control arm from the inside.
The nut came off fine but the bolt is apparently rusted to the steel bushing it passes through.
As I started to hit it with a small sledge hammer the rubber started to deform. There did not appear to be an movement between the bolt and the steel bushing. I did not want to break or bend anything that is hard or expensive to replace so I aborted the mission.
Can anyone give me some insight as to what that bushing assembly is like? Can I buy a new one by itself or is it part of the lower control arm? I am not going to replace the control arm. No way. The car is pretty rusty under there and I don't want to remove too much or I am asking for trouble.
The replacement spring is a Moog which is a little bit bigger in diameter than the OEM.
This makes it impossible to fanagle it in with out dropping the arm or disconnecting the ball joints.
If I can sawsall off the inner bolt some how and replace the bushing and bolt that may be reasonable. I don't know if that part is available and what it may be called.
Any insight appreciated.
Thanks.
Thanks.
