Okay, I've read several topics on this subject, but I'd just like to cover all the bases with this one. Just replaced the thermostat on our 99 Taurus Vulcan because we've been getting either no heat, lukewarm heat, and some case when the stars are right, good and hot heat. The car runs at normal temperature and shows no signs of even being close to overheating. So I figure it can't be a heater core if I actually get heat once in a while, right?
So here are the questions:
1. Will air in the cooling system affect the heater?
2. We've had to add some fluid lately. Will low coolant levels affect the heat?
3. What about this 'blend door' I've heard about. How can I tell if it's working and how hard is it to correct if it isn't?
4. Could it still be a heater core if I got hot heat right after I replaced the thermostat? (and every so often)
Other than the heat, the car acts, looks, and runs fine. Don't see any fluid or steam coming out (but that doesn't mean it isn't leaking when I drive I guess).
Thanks!
Thanks!
