I have a 2001 Taurus SEl. The low coolant light comes on and off for no real reason. The coolant level is fine, I am guessing the sensor is bad.Where is the low coolant sensor located? Is it the sane as the temp sensor? Thanks.
QUOTE (woody367 @ May 27 2009, 07:09 PM) index.php?act=findpost&pid=728474
I have a 2001 Taurus SEl. The low coolant light comes on and off for no real reason. The coolant level is fine, I am guessing the sensor is bad.Where is the low coolant sensor located? Is it the sane as the temp sensor? Thanks.[/b]
They're not the same sensors. The level sensor is on the bottom of the reservoir jug. It is actually integrated into it, so it's not replaceable without a new reservoir. I'd just unplug it.
when you replace it, would you mind posting a picture of this level sensor?
I have a 2001 SES Vulcan bull and my reservoirs have never had sensors in them. Nor do I see any hook up in the engine bay (passenger side) where one would attach to.
No the pre '96 Tauruses have a completely different tank. The older ones just need to be kept 1/2 full or so.
