Bought this car over weekend for $500. was under impression from seller that only had water in gas as it sat where a friend had 5gal gas jug they poured in before making a trip that was pretty watered down.
Seemed all well and good. siphoned tank, changed fuel filter, after towing home. No go. started to get a couple fire but that's all.
There was water in gas tank. But not the problem.
Took out all plugs and turned over pumped out nice gray water. also was building some pressure in overflow tank. real nice.
Did compression test. plugs out and just turning over, 1-80, 2-35, 3-75,4-80, 5-30, 6-65.
In the middle of tear down.
Seems odd to blow both heads? Is this common? What are chances either or both are now warped?
