I am wanting to do a extreme static drop on my gen 2 Sable. Im not worried about ride quality as it will not be daily driven. Im aiming for 4 to 5" of drop. I was thinking a set of SHosource ground controls and strut tab mod. would use camber bolts and camber plates to get adjustments as close as possible.
Opinions?
That is probably the only way. We are working on a true from the ground up coilover kit. It will be much better and be a full kit.
You would need our caster camber plates and adjustable rear control arms.
Around $1500 with no work needed.
You would face that even with the ground control kit which require Konis and our caster camber plates.
For that price would hydraulics be a better choice for low ride ? It is a car Potentially going to be a show car
Well depends on what you plan to do. The coilovers will be good for a low ride. The hydraulics will probably cost more as it might be a custom setup but will allow for you to quickly adjust.
Its hard to be cheap on a non-typical show type car.
