i'm actually gonna get it tomorrow, it's in immaculate condition, the guy had a stack of reciepts like a foot high. like oil changes going back to 1996 are fully documented, it's crazy.
anyway the windshield washer pump will not spray anything when you push in the end of the turn stalk, no matter what. also, the wipers will not automatically come on when you push it in either (i think they're supposed to?) i think maybe once the wipers came up but that's it. the guy said he had it spraying earlier that day. the pump makes no noise and the reservoir is full. also, for a while the 4-ways would not work until i pressed the turn signal down (left turn) then the 4-ways turned on. i was then able to return the turn signal to normal and remove the key and the 4-ways kept working. the car has 257,000 km on it so i figure maybe the multifunction switch? otherwise the car is like mint.
oh yeah and the parking brake won't illuminate the brake idiot light, but it lights up when the bulb test is run in the ON position. switch?
thanks all.
thanks all.
