so i replaced my lightbar bulbs, and it seems only one section of the 4 works, is it possible that they just burnt out? or that the harness itself is f'd up?
It's possible but unlikely.
They're halogen bulbs... you didn't touch the glass, did you?
I would say harness. Check all connections . Make sure they are clean of corrosion. If one side is working I would not think it would be the fuse, both sides on the same fuse..........I think.
Ditto, they're halogens. If the harness is fkd then all the lights wouldn't be on.
