Lengthening a 2004 Ford Taurus
9851 Views 170 Replies 13 Participants Last post by  Taurusup
I have raised a 2004 Ford Taurus up approximately 3.5" at both the front and rear ends and put larger diameter wheel/tire combinations on it. I can describe what I did to accomplish this if anyone is interested.
Here are a few pictures of the finished car.
I don't know why, but I could only download this one picture. For some reason all of the others, while they showed 100% completely uploaded, ended up with a line drawn through the upload instead of a picture appearing. Perhaps someone can help me with this "attachment" problem?
See less See more
5
141 - 160 of 171 Posts
Nice work! You are getting to a final look that maybe could have reached by just adding six inches through the trunk area using the original body parts.
When I'm done, it "will" look quite a bit different than simply "adding six inches through the trunk area". I will, in the end, post pictures "before modifications" and "after modifications".
But your comment does lead me to my next planned step in the modification of the car's body.
jag1959
Joined Jun 26, 2011
#44 · Jul 29, 2022
"Maybe it's the perspective the pics were taken from but I have his feeling when you are done with the rear you're going to end up deciding to kick out the front a bit."
jag1959, I must confess that your comment was never lost on me (I have always thought that the front end of the car was a little too short) but because I did not want to go through the work I tried my hardest to resist making a front end change.
I figure at this point “I’m whipped”. I have already pursued “fins” and wasted alot of time and money, so I figure if I don’t end up with the look that I am after by the time that I invest money in finishing it (painting it) that I will have really wasted my time and money. So I intend to bump the front end out perhaps 5” while moving the engine carriage (and consequently front wheels) forward 2.5”. This will not only lengthen the front end but would also give me a 2004 Taurus that could comfortably fit 33” overall height wheel/tire combos at all four corners (not that I would do it).
My initial thoughts are to completely strip the front end (bumper and its cover, fenders, hood, etc.) Then move the mounts for all of these items (bumper, radiator, fenders) forward 5”, through extending the frame rails if necessary. Then move the engine cradle assembly mounts forward 2.5”. I figure that because I intend to increse the size of the front wheel wells approximately 5” (just like the rear of the car) that I can simply purchase some sheet metal to fill in the gaps at the top rear of fenders (the portion behind the wheel wells). The only thing that I anticipate purchasing at this point in order to make these front end changes would be a second hood, which I would use the rear 5” of to extend the length of my current hood.
More to follow…..
See less See more
  • Like
Reactions: 2
As far as the front end body modifications, I think that I will start by ‘mocking up’ a drawing with the front end body panels (and front wheels) moved forward certain distances to see what yields good balance to the car in profile.
I am currently making some modifications to my rear spindles in order to pitch the trailing link arms more horizontally. When I finish with this and remount the rear wheels, I will take some pictures of the car in profile, and mock up a profile drawing in order to determine how much longer I want to make the front end and where to place the front wheels.
More to follow….
  • Like
Reactions: 2
I finished my rear spindle modifications and have remounted the rear wheels, and taken some profile pictures of the current car (pictures). I think at this point that I am going to extend the front of the car 7” while moving the front wheels forward 3.5”. I do not want to go any longer because the hood will become too heavy for is supporting hardware (pneumatic lifts).
My plan at this point is to strip the front end so I can get a better idea of the ‘structure’ that will be reqired for my front end modifications.
More to follow…..
Automotive parking light Tire Wheel Car Vehicle
See less See more
2
  • Like
Reactions: 1
After studying my profile pictures and considering the work involved to move the engine cradle assembly forward 3.5” and the front body features forward an additional 3.5” I have decided that it will simply be easier to move everything forwad through welding new sections into the upper and lower frame rails on each side of the engine compartment. I have decided to go with a 5.5” increase in length. I plan to move the engine "cradle assembly" forward 4.5” while moving the front end parts forward an additional inch.
In order to make these modifications I plan to make new rear "cradle" mounts, which will be located 4.5" forward from the current ones. After making the new rear "cradle" mounts I will attach the cradle and use it to locate front cradle mounts, to the frame of the car which I will lengthen 5.5" through the upper and lower frame rails through adding 1/8" steel plates.
I have developed a plan to execute these modifications as simply as I can. First, I will place the front of the car on the stand that I made last time at a position at the front of the car's outer frame rails (just behind the current rear engine cradle mounts). Then I will disconnect (or cut) all lines and attachments from the car's firewall to the car's engine (plus the exhaust pipe) to accommodate the lengthening of the front end. Next, I will place the engine cradle with the front engine cradle mounts still attached (in order to support the front end features of the car during the move). After that I will use my pallet jack with blocks to support the engine cradle/front end of car assembly. Next I will cut through the upper and lower frame rails on each side of the engine compartment just in front of the strut mounting plates (separating the front of the car from the rest of the car). Then I will disconnect the rear engine cradle attaching bolts, and use the pallet jack to relocate the engine cradle/front end assembly to a position where I have plenty of room to weld in new rear cradle mounts. Once the new rear cradle mounts are in place, I will reattach the engine cradle to the new mounts. At that point I will develop a plan for filling the gaps in the frame rails.
More to follow…..
See less See more
  • Like
Reactions: 2
Well, I am well under way on the front end modifications.
I have stripped the front end (picture), …placed it on the body support mount that I had previously made (picture), …cut the exhaust pipe, …disconnected the steering linkage, …disconnected a few heater hoses, …and unfortunately had to cut the two AC lines because they will have to be lengthened.
After preparing all the lines and hosing for the move, I placed the engine cradle/front end assembly on blocks on my pallet jack, disconnected the rear cradle mounting bolts, and cut the upper and lower frame rails on each side of the engine compartment. Then I moved the engine cradle/front end assembly forward 5.5” and downward slightly to make room for new rear engine cradle mounts.
Because I am now moving the rear engine cradle mounts forward, I can no longer use their existing frame constrained nuts. Because the new mounting location is now 3” in front of the firewall, I fabricated two diagonal columns of 2.5” pipe with 3/8” plate welded to is bottom end, and with cutouts in their lower side walls to access nuts for mounting the rear of the engine cradle in its new position (picture).
More to follow…..
Car Vehicle Automotive lighting Motor vehicle Hood
Tire Wheel Vehicle Automotive tire Motor vehicle
Bumper Bat Tints and shades Automotive exterior Quill
See less See more
4
  • Like
Reactions: 2
All I can say is WOW!!!! You must really like the Taurus or enjoy a challenge and metal working.
My thought would be "both" rather than "or"
After yesterday's session I don’t know if I would use the word “enjoy”, but I will confess that I am driven by something.
Wow!!! when I think about what it would be like to have a car lift, where I could stand under the car to weld…..
Well, with a good deal of access difficulty (‘worming’ around on my back in the 12” gap between the bottom of the car and the ground - actually 10” under the support dolly) I finally got the rear cradle mounts welded in (pictures).
In order to further strengthen the car’s frame to accomodate slightly increased tensile stresses at the base of the forward end of the passenger compartment due to moving to front wheels forward, I welded a short section of 2” x 1/4” bar from the back side of each of the two rear cradle support columns to the car’s reinforcing channels at the lower front of the passenger section on each respective side of the car (it can be seen in the pictures). Once I had the rear cradle mounts welded in, I painted them.
Now that the rear engine cradle mounts are integrated into the car’s body I can fabricate and weld in the new front engine cradle mounts and then work on extending the upper and lower frame rails on each side of the engine compartment.
More to follow…..
Automotive tire Motor vehicle Bumper Rim Automotive exterior
Automotive tire Hood Motor vehicle Tire Tread
Motor vehicle Automotive tire Hood Automotive design Tread
Automotive tire Motor vehicle Wheel Automotive lighting Tire
See less See more
4
  • Like
Reactions: 1
I have fabricated new front engine cradle mount columns out of 2.5” pipe with openings in their side walls, just like the rear mounts (pictures) so that I can access nuts for mounting the engine cradle assembly’s front ends. Once I fabricated them I mounted them to the front of the cradle assembly after rotating it to the proper pitch. Once the cradle assembly was located to the proper pitch (front to back), I let the front end simply set on the cradle mounts to support it heightwise (picture), then I clamped a couple of straight bars in the gaps in the upper frame rails to maintain a 5.5” gap (picture). After this I used a template which I had previously made of the original sweep of the upper frame rails in order to pitch the front end into the proper position. With the front end located in the proper position, I welded the front cradle mounts in place to the bottoms of the frontal frame rails, and painted them (pictures).
Its time to fill in the 5.5” gaps in the car’s upper and lower frame rails on each side of the engine compartment. To do this I formed the 5.5” long 1/8” plates shown (picture). My plan is to weld these new sections in (starting with the inner one closest to the engine) from the outside (the wheel well area) so that I dont have to move the engine out of the way.
More to follow…..
Automotive tire Alloy wheel Drinkware Rim Soft drink
Automotive tire Hood Motor vehicle Automotive design Automotive exterior
Automotive tire Motor vehicle Automotive fuel system Rim Gas
Automotive tire Light Motor vehicle Automotive fuel system Automotive wheel system
Motor vehicle Automotive tire Automotive exterior Rim Gas
Automotive tire Grey Door Bumper Automotive lighting
See less See more
7
  • Like
Reactions: 3
With the “cradle assembly” already mounted to the car at all four corners and the frame rails aligned with each other, I started welding in the joining pieces. I started with the lower frame rails by welding in the inner angled plates (closest to the engine - picture), welding them in from the outside. After they were welded in, I welded in the outside angled plates (picture), again welding from the outside.
Once the lower frame rails were joined together, I welded in the upper frame rails starting with their upper angled plates (picture), then finished up with their lower angled plates (picture).
More to follow…..
Wheel Automotive tire Tire Motor vehicle Bumper
Hood Motor vehicle Automotive tire Automotive design Bumper
Automotive tire Hood Motor vehicle Automotive lighting Automotive design
Automotive tire Hood Motor vehicle Bumper Gas
See less See more
4
  • Like
Reactions: 2
It is now time to address the strut mounts. I have decided to scrap the ones that I previously made when I raised the front end, and make two new ones which will attach between the upper and lower frame rails (making for a rigid and strong front end framework). In typical fashion I made a flatpattern cardboard template (picture) which I transferred to 3/16” plate, then cut it out and formed a symmetrical pair of strut mounting plates to be welded between the upper and lower frame rails on each side of the car (pictures).
To locate and properly ‘pitch’ these two strut mount plates, I noted the “gap” between the front suspension’s lower control arms and the cradle assembly’s frame when the front end of the car was ‘loaded’ and sitting on its wheels. I duplicated this gap (which should theoretically be close to the neutral sitting height of the front of the car when finished) and drew a line from the centerline of the strut tower clamp to where the centerline of the strut mount plate should be located for proper ‘toe in/out’ pitch of the wheels and proper pitch rearward of the front suspension. I had already noted where the centerline height of the strut tower mounts should be relative to the upper frame rails. With this information I developed and fabficated the strut tower mounts. After locating these two strut mount plates in the proper positions, I welded them in between the upper and lower frame rails on each side of the car, starting on the passenger side, then using it for a model for the driver’s side (pictures).
More to follow….
Road surface Asphalt Tints and shades Circle Wood
Automotive exterior Bicycle part Bumper Composite material Rim
Footwear Shoe Basic pump Automotive design Grey
Car Vehicle Hood Automotive lighting Motor vehicle
See less See more
4
  • Like
Reactions: 2
Excellent work! Original mounts have larger bolt holes and use a top plate to enable adjusting the camber. Cut the top plates off the old mounts to act as a large washer. I drilled out the tack welds on the original plate to enable camber adjustment. Also maybe it doesn't matter but the orientation of the holes are opposite of OEM. I know the bearing plate can rotate but not sure if that effects the spring cup orientation..
Automotive tire Alloy wheel Motor vehicle Locking hubs Rim
See less See more
  • Like
Reactions: 1
Thank you Automender12345,
I reversed the hole pattern (180°) to make access to the lone hole on the non-equallateral triangle which would otherwise be up against the inside of the break in my new strut mount plates (it was simply an access issue). I am hoping that reversing the holes does not effect the spring cup orientation. If so I can simply drill three more holes in my mounts in the proper orientation.
When I think about the 'radical changes in camber' brought about by the individuals who change the factory height of their cars (especially lowering them down until their chassis almost touches the ground), I don't feel so bad about my suspension.
Note: In placing the spring seats (the mounts) I did move them closer to centerline of the car to help "square up the wheels" when the car is sitting on the ground.
See less See more
  • Like
Reactions: 1
To further accomodate slightly increased compressive stresses at the upper front of the car’s passenger compartment due to moving the front wheels forward 4.5”, I welded in two reinforcing plates (one on each side) joining the back of the strut tower mounts to the car’s passenger compartment (pictures). Once these plates were welded in (picture), I welded in a new mount for the engine’s upper torque mount link on the pasenger side strut tower mount (picture). Next, I cut out and formed a couple of 18 gauge plates to fill the 5.5” gaps in the fender wells between the upper and lower frame rails where I had separated the front and back sections of the car’s front end. Finally, I rewelded on a few brakets on the driver’s side fender well which attach a few of the engine compartment components (picture). With all of these modifications to the frame rails/engine compartment complete I painted everything (pictures).
At this popint I think I will put the car back on its front wheels.
More to follow…..
Hood Automotive tire Motor vehicle Bumper Automotive exterior
Tire Automotive tire Hood Motor vehicle Tread
Automotive fuel system Hood Motor vehicle Automotive tire Vehicle
Hood Motor vehicle Automotive tire Automotive exterior Automotive lighting
Hood Automotive tire Motor vehicle Automotive design Automotive exterior
See less See more
6
  • Like
Reactions: 1
I put things back together in the front suspension and remounted the wheels.
Automender12345; it turns out that you were correct regarding changing the spring cup orientation through my rotating it 180°. I corrected it by drilling new hole in my strut mounts (pictures). When I remounted the strut towers I realized that I had reoriented my holes for nothing. I don’t know what I was thinking at the time, for some reason I thought that the fasteners had to be accessed from below, which isn’t the case (they have studs that push up through the mounting plate where the attaching nuts are easily accessed from above). I feel foolish, I obviously don’t think of everything.
More to follow…..
Automotive tire Font Automotive wheel system Gas Auto part
Motor vehicle Automotive tire Automotive lighting Automotive exterior Automotive wheel system
See less See more
2
  • Like
Reactions: 1
At this point I will turn to modifying the car’s components which will have to be elongated to accomodate the moving of the engine cradle assembly forward 4.5”. They include the steering shaft which will have to be made longer because the steering box moved with the engine cradle, the shifter cable, the exhaust pipe, the air conditioning lines, possibly the wire harness and heater hoses.
  • Like
Reactions: 1
I started with the exhast pipe. First, I disconnected it where it meets the exhaust manifold just under the engine. It turns out that if I cut the weld at this flange and simply rotate the first section of the exhaust assembly it raises the exhaust pipe up into the original cavity. I have decided to add two flanged joints to the exhaust system, changing it from one section to three sections. I decieded to work backwards from the rear of the car forward when making the sections because this forward joint is easy to access.
Pictured is the ‘new’ rear section of the exhaust system (the portion behind the rear joint). The rear muffler use to hang from a bracket that carried it significantly under the frame rail at that location (a good 4”). In order to move the muffler upward toward the frame rail, I welded a little ‘horn’ on its front edge (picture) which will slide through a cylindrical rubber bumper mounted in a tube welded to the bottom of the frame rail. This ‘set-up’ will move the muffler upward 2” (just under the frame rail) where it won’t be visible in the car’s profile. In order to make the muffler easy to remove (through sliding it forward off of the ‘bumper engaging ‘horn’ at its front end) I added the rear flanged joint to the rear of the exhaust system just above the rear control arms.
The center section of the exhaust system (pictured) joins the rear and forward sections. And the forward section joins the center section to the engines exhaust manifold. I added a few pictures of the new exhaust system before installation.
More to follow…..
Plant Road surface Automotive tire Asphalt Grass
Road surface Asphalt Bumper Concrete Tar
Composite material Metal Bumper Bicycle part Auto part
Tool Composite material Nickel Metal Fashion accessory
Automotive lighting Automotive tire Hood Wheel Motor vehicle
Hood Automotive tire Automotive exterior Tints and shades Fender
See less See more
6
  • Like
Reactions: 1
See this forward exhaust system mount (picture); it just may cost me a $1000 before I’m done. It turns out that after welding it in place, the process started a fire under the dashboard, which, by the time I quenched it, has probably caused considerable damage under my dashboard. Whatever this pile of melted plastic is (picture), I’m sure that it is no longer functional. Heat, coming up through the defrost vents also took out my front window (picture). Anyway, I have the exhaust system installed.
Not a good day on the project.
Any advise on dashboard removal would be appreciated.
More to follow…..
Automotive tire Bumper Automotive exterior Gas Automotive wheel system
Tire Wheel Automotive lighting Automotive tire Hood
Automotive tire Motor vehicle Gas Bumper Automotive lighting
See less See more
5
