It is now time to weld the Riviera’s rear end onto my frame rails.
I started by placing the bumper cover over the bumper
(already mounted to the frame rails) to determine what pitch would flow best at the lower end
(the line that defines the lower profile of the car’s body from the back of the rear wheel wells to the base of the rear bumper). After determining the pitch which best fit my plan. I determined what height I had to make the perimeter of my trunk floor in order to attach the Riviera’s lower side and rear body panels at the trunk.
After “fitting up” the Riviera’s rear to my modified rear car body
(by simply placing it on top of it), I discovered
(with not much surprise) that it is too tall
(especially at the rear bumper) to meet the lines for the profile that I am after. This didn’t come as a surprise, because I knew that in extending the car’s length at the back end ‘sections through the car’
(including their heights and widths) will become larger on any tappered car
(and most are) as they move rearward from their originally designed position. This simply means that I will have to cut the rear end into upper and lower halves, and ‘fit’ them to each other to follow my envisioned body lines.
Unfortunately, I have come to the conclusion that if I am going to get the body lines that I want at the rear end of this car that I am going to have to sacrifice the Buick Riviera’s light bar. That was not only some money wasted for an unnecessary light bar, but I still have the problem of finding somewhere to place rear lights.
The logical place to split the Riviera’s rear end into upper and lower sections would be right where its plastic rear clip/bumper cover mounts to the sheet metal, as this is not only the widest place, but also the division point between steel above and plastic below. So I layed out and cut the Buick’s rear end into upper and lower sections through the sheet metal 1/2” above the ‘shelf’ where the plastic bumper clip mounts to, and through the center of the light bar in the rear
(pictures). This would be a safe place to make my cut, as I would have excess material both above and below this line to make final trim adjustments later.
After cutting the rear clip of the Buick Riviera into upper and lower portions, I used my ‘mocked up picture’ of the profile that I am after to determine the height for the forward ends of the bumper clip
(back of the wheel wells) that I thought flowed nicely.
The lower side panels contain the “shelf” which mounts the pastic bumper cover
(lower part of the body of the rear end of the car), so I started by trimming these panels to meet three floor panels which I would extend out from my frame rails. To determine where to trim these panels, I mounted these ‘bumper cover mounting panels’ to the bumper cover and clamped the bumper cover up against the bumper at the rear while bracing its two sides at the front edges to a height that I thought flowed nicely to my ‘mocked up picture’ in profile. Once I determined both the height of the perimiter of the trunk floor where it met these three panels, and their profile at the perimeter of the rear of the car
(where they would hold the bumper cover in the proper position to meet my plan), I layed out and cut these three sheet metal panels
(one for each side and one for the rear) out of 18 guage sheet metal. Once cut out I weled them to the frame rails and rear of the wheel wells to establish the remainder of the floor of my new trunk
(pictures).
Finally, I welded the bumper cover mounting panels to the rear floor panels at the right and left sides of the car
(pictures).
More to follow….
