Ended up going with the leds. They work great! I'm going on 3 weeks so far, no issues as of yet. I'll post any updates.Leaving aside the legalities, the LED lights usually end up generating a LOT of heat at the base and you'll have to cut up the rubber caps on the assembly in order to make any installation work, and I'm not sure how this would go while still keeping out the moisture the cap was designed to prevent in the first place.
I second this. I would like to see pictures.Install pics? Any flashing from other drivers?
Need some projection pictures to really be able to tell. That doesn't really show us much.Took this today... I never get flashing from other drivers.
The cutoff should be your biggest concern. If an oncoming driver is blinded by you and drifts over the center lane, due to the fact that you have dangerous aftermarket equipment you could get sued pretty seriously.Was just looking for something better than stock, but reasonable cost... paid $78
I think they work great and nice looking. Wasn't really worried about the cutoff
Thanks for your concern, they aren't blinding like you are thinking... I had my wife drive behind me as well as toward me while I was in her car. They were fine.The cutoff should be your biggest concern. If an oncoming driver is blinded by you and drifts over the center lane, due to the fact that you have dangerous aftermarket equipment you could get sued pretty seriously.Was just looking for something better than stock, but reasonable cost... paid $78
