1 - 15 of 15 Posts
today i swerved and slammed on the brakes on wet pavement to avoid a deer. I ended up in a cornfield. When i got out my RF tire was loose on its rim, i was leaking coolant and the LR wheel was leaning in at the top. I fixed everything else, but the LR tire is still messed up. It is driveable, but the tire is rubbing on the strut tower....i think.....any ideas on how to fix?
look under it to see what is bent. It can only be a few things, lower lateral arm(control arm)X2, strut rod, knucke, or strut.
[attachment=29255:rear_suspension.jpg]
Discussion Starter #10
I'll take the wheel off tomorrow and look and then probably end up taking it to the shop. I'll let you know what i find out
Discussion Starter #11
QUOTE (c2harvey @ Apr 22 2009, 09:56 PM) index.php?act=findpost&pid=719781
I'll take the wheel off tomorrow and look and then probably end up taking it to the shop. I'll let you know what i find out[/b]
took the wheel off and everything appears ok, including the strut. I managed to bend something back by pushing down on the wheel, so it no longer rubs, but it is very close to the strut. The only thing i could see damaged was the rubber on what i think is the swaybar endlink.
QUOTE (c2harvey @ Apr 23 2009, 06:24 AM) index.php?act=findpost&pid=719871
took the wheel off and everything appears ok, including the strut. I managed to bend something back by pushing down on the wheel, so it no longer rubs, but it is very close to the strut. The only thing i could see damaged was the rubber on what i think is the swaybar endlink.[/b]
Go ahead a take some pics anyway, maybe someone will see something you don't. A pic is worth a 1000 words. ;)
The large eye where the strut rod attaches will bend and is very difficult to see.
Probably need a new hub.
Discussion Starter #15
Got it checked out....turned out to be a bent strut, right at the pinch bolt. The lower radiator hose is also cut. I drove it home about 6 miles and it didnt leak at all and then sat for ~18 hours and still fine. Then I drive it to the garage 1 mile away and its leaking when they pull it in.
1 - 15 of 15 Posts
