1 - 2 of 2 Posts
I replaced the rack in my car due to it leaking out the boots. Swap went pretty good, except I have had a slow leak from where the two lines go into the rack. I can not see if it is one or both leaking as there is no room to stick my head in, and can not tell for sure otherwise.
I tried tightening them up, and they are tight, but still have a leak. Has anyone had a similar problem?
I am getting tired of the stain on my driveway :angry:
thanks in advance
There are 2 small nylon seals between the lines and rack. Ck you're local a.p. Store ask for dormann/motormite part # 82540 should be less than $3 bucks. This should seal it up nice. As for the oil spots pour a 2l of coca cola on it and let it sit overnight then rinse w hose. Works well. Best of luck.
1 - 2 of 2 Posts
