From this little rectangle hole in the firewall on pass side? What is it for? Maybe heater core? Started 2 days ago. No a/c or heater is being used currently.
Here is pic. It is circled in yellow. Click to see big view.
Uploaded with ImageShack.us
It's just the drainage hole for the A/C condensor. The condensor and heatercore are both contained in the same boxed in piece. The water off of the condensor drains out that hole. When you say the A/C or heater is not in use, is the HVAC in the OFF position? If it's on DEFROST, DEFROST/FLOOR, PANEL VENT/FLOOR, or A/C the Compressor runs so you will get condisation coming from it.
I mean the heater is not on (105 out yesterday/ no hvac on at all) and ac has issues so it is not being used. Assuming then this means the heater core is leaking right? Can it be bypasssed for now till it cools off a little to work on it?
Just run a piece of heater hose from the outlet on the waterpump to the inlet by the thermostat housing. Instant bypass!
